Posted by El Toro on September 04, 2009 at 03:57:14 from (205.188.116.73):
In Reply to: can't keep 706 running posted by ixkaped2 on September 03, 2009 at 19:38:25:
You have a fuel blockage somewhere between the tank and carburetor. Disconnect the gas line at the carb and see if there's a full stream of gas from from the line. Hold a clean container to catch the gas. If this is just has a trickle you need to clean the tank and gas line. If there's a full stream from the line then the carburetor may be the culprit. It may have a screen behind the fitting where your gas line connects that's full of rust and dirt or the carb needs a good soaking in carb cleaner and cleaned thoroughly. If that carb has a main jet adjustment screw like the one's used on the Farmall M & H you need to open it. Garden tractors have that too. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
