I vote for lost motion in the linkage, either in a shaft to lever, or in the clutch cover itself. A month ago a cover was discovered with oval pivot points for the release levers that allowed it to push in 3/4" (about) before actually pulling back on the Friction plate. If it is a rebuilt clutch, it might be that. A warped disk with a sprung hub center will not release well either. The only other item is the flywheel offset depth from bolt surface of the Clutch to the friction surface. If cut wrong, it will not work as designed. JimN
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
