Re: Can you run a log splitter off of the M
Posted by M Diesel on September 04, 2009 at 11:47:27 from (12.24.61.12):
In Reply to: Can you run a log splitter off of the M posted by KC Bob on September 03, 2009 at 14:42:39:
Belly pumps might go as high as 1200 if tweaked, but 750-800psi is the spec. They make just under 8 gpm at full load, as high as 10 at light loads. Problem with a splitter is they really need a dual speed pump. Those normally are rated at 12 to 16 gpm at 400 psi (for a quick approach) and then drop to 3.5 gpm at 2500 or so when the real load hits. Selecting the right cylinder will allow the belly pump to function okay, but it won't be all that quick. Depending on circumstances, that may not be a concern, especially if the workfactor knob isn't turned up very far.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
