Re: belly pump delayed lift revisited
Posted by JLE on September 04, 2009 at 13:33:13 from (68.28.138.232):
In Reply to: Re: belly pump delayed lift revisited posted by Janicholson on September 04, 2009 at 09:20:44:
The delayed lift was a result of having 3" cylinders on the front units and 21/2" cylinder on the rear unit. Results, the front units raised first, the the rear because it took more pressure to raise the smaller cylinder. The drop was as described in other replys. Jim E.
