Engine block identification
Posted by cbna on September 04, 2009 at 14:31:20 from (64.12.116.73):
I have a engine block it has a dip stick behind oil element a block off plate for fuel pump and a cut out on the right rear engine mouting flange. I think it is a c-113 or c-123 maybe c-135. The part no. on side of block is 356318 r-2 casting no.5-35-y the serial on block is IMAM-G 10651. I think it maybe a engine out of a windrower or combine maybe hay swather Thanks for any help mike
