Re: do I need the wheel weights on my A?
Posted by charles todd on September 04, 2009 at 18:10:02 from (205.242.95.137):
In Reply to: do I need the wheel weights on my A? posted by Bryan Monaco on September 04, 2009 at 16:02:51:
I'd say safely no. Weight is needed for traction (drawbar work) or ballast (front end loader). Enjoy your red iron.
CT
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
