Re: Cleaning Zollner Pistons...
Posted by MeanGene1 on September 05, 2009 at 08:33:42 from (204.14.185.168):
In Reply to: Cleaning Zollner Pistons... posted by Crazy Red Power in SE-WI on September 05, 2009 at 07:22:20:
You can squirt the rings & pins with PB Blaster or similar, or soak them in ATF, give 'em a day, tap the rings very lightly around the circumference with a light hammer, repeat until they come loose- patience is the best tool. The pins will free up, too, probably not necessary to pull them out. You can lean the fuzz off the pistons and from the rings & grooves with a soft wire brush, won't scratch the pistons like steel wire
