Re: '47 Farmall H Dash switch
Posted by wfd2 on September 05, 2009 at 12:20:21 from (173.100.44.63):
In Reply to: '47 Farmall H Dash switch posted by wfd2 on September 04, 2009 at 16:19:05:
Thanks Mike & Tom!
Mike, I believe "off" means lights off, correct? Not charging system off...
As I said, my '47 H is still the 6v system. I considered transfering it to 12v for better charging/starting but haven't done it yet. I'm not sure the 6v system even works because someone removed all the wires. (I think the VR, generator, or both is fried otherwise why would a previous owner hack out all the wires??
I'm also having problems with starting system. The starter turns over very slowly or not at all, even with a new, charged 6v battery (I checked, it's now ~6.3v). The wires to the starter get warm. Another person said to check the ground to the starter-- it could be a bad pos. ground. I'll check that tonight.
