Re: sleeve removal in H Farmall
Posted by El Toro on September 05, 2009 at 13:28:54 from (74.103.74.187):
In Reply to: sleeve removal in H Farmall posted by wendell blanton on September 05, 2009 at 10:45:45:
third party image
You need a puller like Keith made for his Super C. You will need a puck undercut to 3.355" to fit the sleeve bore if the sleeve bore is 3.375". The overall diameter of the puck should be about .020" less than the overall diameter of the sleeve so it will clear the block diameter. Hal
