Re: sleeve removal in H Farmall
Posted by glennster on September 05, 2009 at 17:08:40 from (24.14.63.246):
In Reply to: sleeve removal in H Farmall posted by wendell blanton on September 05, 2009 at 10:45:45:
like hal said, you will need a sleeve puller. if you cant build one or borrow one, if the motor is out of the tractor, take it to a local engine shop and have them pull the sleeves for you. also have them check the height of the new sleeves at the top where they go in the block, if the stick up too high, they will need to be machined down. (just had this done on my super m motor)
