If it's right where it joins to the tank, I'm pretty sure that's a brazed joint. It'll take some prep work in the surrounding area and a good fluxing, but you could try soldering it. If that doesn't hold, it should be an easy fix for any competent radiator shop.
If it is a solder joint anyway, then solder is your answer. All I'd add is that if it were mine, I'd dismount the radiator and lay it flat to attempt the repair myself. My luck (and soldering skills on large stuff) I'd get the whole thing too hot and the pipe would fall right off.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
