Re: W-6 Questions,
Posted by Jeff Z. on September 06, 2009 at 07:34:31 from (74.76.3.113):
In Reply to: W-6 Questions, posted by F.,K, on September 06, 2009 at 07:04:21:
The one problem with straight pipes is cool air rushing in after the engine is turned off.
If you use a straight pipe cover the top of it with something when you shut down the engine.
This will keep heat in.
Let's the head cool slowly.
If you have ever been to a drag strip you will see the crew plug the headers on the engine as soon as the run is over.
