If you allready checked the mag and you say it is indeed dry I would then have to agree with the gentleman below. It's likely a restricted airflow from carb to air cleaner (water in air cleaner). Easiest check would be to pull the hose off the carb that runs to the air cleaner and then fire the engine. If the symptom disapears the problem is in the air cleaner. If not it's possible that water got past the air cleaner hose into the carb intake, I have had that happen before as well. As for the governor, unless a part inside failed at the same time you powerwashed it I would say no. The governoring mechanism is all internal all the way to the carb so powerwashing should not have affected it.
I used to always have problems like this when I powerwashed my tractors. I now use a garden hose hooked to a hot water faucet, a good hot bucket of soapy water and a wash rag for the tinwork and a good commercial degreaser and a heavy scrub brush for the frame and places where the grease is. My problems have all but disapeared keeping the powerwasaher away from the tractors. Just some food for thought.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
