Re: Distributor timing on older machines.
Posted by kopeck on September 06, 2009 at 18:17:08 from (74.209.51.58):
In Reply to: Distributor timing on older machines. posted by Bob on September 06, 2009 at 18:00:17:
Bob said: (quoted from post at 18:00:17 09/06/09) The "B" DOES have a "TDC" mark and after measuring the circumference of the flywheel it will be EASY to make a second mark @ about 25º or 28º and check if the distributor is advancing the timing into that range @ high idle.
Well, I didn't think about that but then again with out splitting it that's not going to be the easiest thing in the world (that little view hole doesn't give you much space to work). What would you use as a static make to align with?
It would be a bugger laying under the bell housing and trying to adjust the distributor at the same time. Then again maybe I'm just a wimp. :-P
K
