Posted by gene bender on September 06, 2009 at 20:10:27 from (207.177.56.163):
In Reply to: Stepped vs. flat pistons posted by countryboybct on September 05, 2009 at 15:23:02:
If you need power go with the hi-dome ones but you will probably need to install as dist so it will start as the mag fires at TDC. I had to go to a dist when i put 3 1/8 hi-dome pistons and newer head it would not start with the mag intil i insalled a dist so the timing could be advanced as the mag fires on TDC. There was a directive from I-H when the Fire Craters saying a dist had to be installed when using the Fire Craters.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
