Re: h vaccum?
Posted by James Rumph on September 07, 2009 at 05:18:15 from (24.192.125.175):
In Reply to: h vaccum? posted by CJ_1080 on September 06, 2009 at 19:09:09:
We run a vacume gauge on my Super M puller.
We use the gauge to tell us if it needs more fuel.
At idel ? at wide open throttle it should read almost zero. If it has vacume at wide open throttle it is showing you need more fuel.
We put a vacume fitting in just above the carb on the intake.
We have also preformed this test on the dyno to see how load effect timing as well as vacume and fuel.
Good question , most don't think to do this.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
