Re: Farmall M won't start
Posted by Jeff Z. on September 07, 2009 at 09:07:41 from (74.76.3.113):
In Reply to: Farmall M won't start posted by Tractor Plebe on September 07, 2009 at 09:04:04:
If you pull the rotor off that plate should just lift off. You may have to get something under it to pry it up. It is just a dust cover.
