Re: Distributor timing on older machines.
Posted by James Rumph on September 07, 2009 at 09:12:05 from (24.192.125.175):
In Reply to: Re: Distributor timing on older machines. posted by kopeck on September 07, 2009 at 06:08:26:
No you won"t hurt it at 1400 rpm ! If you turn up the governor speed to high you will.
Keep in mind there is only "3" main caps on that crankshaft. There is also "no" bob weights like a car crank so to much rpm will kill it.
Example...
On a "M" motor, a stock cam runs out of power around 1900 rpm. After that the torque #s fall off very fast.
You don"t need alot of rpm to make good power.
