Re: Farmall M won't start
Posted by Brownie 450 on September 07, 2009 at 11:05:49 from (66.43.241.141):
In Reply to: Farmall M won't start posted by Tractor Plebe on September 07, 2009 at 09:04:04:
Looks like the dust cover has been painted - which it shouldn't be. Could be stuck tight with the paint-- might need a pliers to get hold of one of the tabs to loosen it.
