The 30 number is from my 200 manual so that makes sense. The sheet that came with the distributor doesn't have advance numbers, just a basic "this is how you install it".
So...I got everything back where the book said it should be at TDC and guess what, it skips, I retard the timing a bit (turning the distributor clock wise) and it cleans right up.
I'm not really sure what I should do. If I run it where the book tells me to it doesn't run all that well (it's not like I loose a cylinder, it's just a miss every few revolutions), if I run it where it sounds good I'm out of time.
Could there be something simple I'm missing here?
Maybe I'm over thinking and should just go with what works...
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
