Re: Does this super AI sound right?
Posted by Roddy on September 07, 2009 at 14:56:11 from (70.74.68.230):
In Reply to: Re: Does this super AI sound right? posted by Glenn F. on September 06, 2009 at 19:33:18:
Problem found!
I forgot to shut the petcock under the gas tank off the other night. It filled the engine with gas!
I"ll rebuild the carb, change the oil and go from there.
Thanks for the help!
