Re: slidin' wheels
Posted by soybeanjoe on September 08, 2009 at 06:13:35 from (66.213.171.108):
In Reply to: slidin' wheels posted by Gary Hutchinson on September 08, 2009 at 05:54:57:
It would appear to me that when the wheels put pressure against the pipe spacers which in return would put pressure against the outer bearing cap that the spacers would cut into the spacers.
IMO, I would find out why the wheels slid in and ssolve that problem. I have been operating tractors since the mid '50s & the only time I have had a wheel slide is when it was loose.
I was taught that when you tightened wheel bolts that they need to be as tight as you can get them then turn them 2 more turns. WE always use a 4' foot pipe on a HD breaker bar. Tighten till tight then hit on top the axle with a sledgehammer then tighten again. Do this at 2 or 3 times.
Other possibility is that the wheel clamp bolts are bad & act tight but aren't. If you still have trouble with the wheels sliding after tighting like I said I would take the bolts out & check them.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
