Posted by ScottyHOMEy on September 08, 2009 at 07:57:56 from (70.105.237.137):
In Reply to: Re: 1941 Farmall A posted by Joe Joiner on September 08, 2009 at 07:32:54:
Brings up another thought. What kind of lighting do you have? Is it the Bosch no-battery system or the MUCH more common Delco lighting and starting with generator and battery?
If it's the Delco, my best recollection is that it was just a thread of a fuse element inside there, maybe 3 or 5 amps. (A quick spin through teh garage didn't turn up my spares) 20A sounds awful heavy. All that's on it is your lights, so you might want to look around for a short somewhere, chafed wire, bad switch on the rear light if it's a combo . . .
On the really far off chance it's the Bosch system, I've never even laid eyes on one, but I do see that it has two fuses. From the diagrams, one mounted on the switch body, and another separate. No indication in the book of what either of them was for size or load. 8^(
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
