Re: Try to run 460 diesel
Posted by charles todd on September 08, 2009 at 08:23:53 from (205.242.95.140):
In Reply to: Try to run 460 diesel posted by farmall460pa on September 07, 2009 at 10:20:23:
I do not know a lot about a 460 diesel, but I have a 504 diesel and they are similar in size. I have #2 or so cables and a group 31 (big 12v) battery. It starts fine when ever I need it, I can even hold the glow plugs in while cranking the motor. The glow plugs draw 24-26 amps total for four. You may have cable/terminal problems or dragging starter. I also know if the valve lash is out of spec, it can cause compression problems when starting. Simple first.
CT
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
