Posted by mkirsch on September 08, 2009 at 10:12:29 from (64.80.108.57):
In Reply to: Try to run 460 diesel posted by farmall460pa on September 07, 2009 at 10:20:23:
There is only one set of hookups because the tractor is supposed to have two large 6V batteries in series. The + cable goes to the + on one battery. The - goes to the - post on the other battery. Connect the two batteries together - to + using a short cable.
Two 12V in parallel, or two 6V in series. Doesn't matter. End result is the same as far as cold cranking amps go.
DO NOT just buy one 12V battery and add it to the existing one. That is a recipe for a never-ending nightmare of dead batteries. Both batteries need to be purchased new at the same time, and replaced at the same time. When the old battery dies, it ruins the new battery. You replace the old battery, and now the "old new" battery ruins the "new new" battery... With two 6V in series, you can replace either battery at any time without worrying about one ruining the other.
You might be better off finding a bigger single 12V battery. Get a real tractor battery too. Car batteries won't take the abuse of bouncing around a rough field for hours on end.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
