Posted by Tom Fleming on September 09, 2009 at 16:06:21 from (67.20.240.67):
In Reply to: 10-20 manifold stud posted by Tony S. on September 08, 2009 at 21:20:05:
I just wanted to follow up about using heat. Yes, cold cast iron does not respond well to intense heat. However, I have sucessfully removed bolts and broken bolts using Mr. Heat, aka the "blue" wrench.
The key is to gradually heat the cast iron mass, and keep intense heat localized to the bolt itself. I have heated engine heads in the oven to 300 degrees, and then used a torch to heat the bolt itself.
Above all, what ever method you use, patience trumps all. It took years for a bolt to rust solidly into a cast iron block or head. 15 minutes will not remove it without great risk of damage.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
