Posted by c.perkins on September 09, 2009 at 17:49:58 from (24.60.214.124):
In Reply to: glow plug check posted by farmall460pa on September 09, 2009 at 17:40:10:
best way I found is to use a test light ground the light to terminal on the glow plug and probe the wire terminal. if it lights the plug should be good. But GLOW PLUG SHOULD ALWAYS BE REPLACED AS A SET if you only change the ones that are not working they and the other will fail and in the end you will buy more plugs then if you changed the set
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
