Posted by Janicholson on September 09, 2009 at 17:52:31 from (64.61.211.219):
In Reply to: glow plug check posted by farmall460pa on September 09, 2009 at 17:40:10:
I think they are in series like old small base Christmas lights. As someone helps by pushing the button when you say push, check for voltage to ground along the circuit. If one is bad there will be no voltage going to the next plug, but voltage going into it. A simple continuity will also work most of the time, unless the glow filament is touching the contacts until it is given full voltage. Shorts to ground can also happen, burning out several at once. Good luck, JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
