Re: Thanks -- 350 Utility Temp Gauge Reading
Posted by CNKS on September 09, 2009 at 18:47:39 from (216.144.104.128):
In Reply to: Re: Thanks -- 350 Utility Temp Gauge Reading posted by rumplestiltskin on September 09, 2009 at 18:07:57:
The manuals don't always agree with the real world. If you have the correct gauge, any movement into the hot area means 212 degrees F. "Correct" temperature probably means about 180, which is likely the center of the green area. The H I drove in the 50's under most loads ran about 2/3's into the green under a full load. If it was a hot day and fully loaded, it would slowly move over to the red. Only way to prevent that was to shift down a gear. On the other hand, lightly loaded and cool weather will it will usually move barely into the green. My opinion is your gauge is reading correctly. Those tractors are cold-blooded, except when they are pushed, then they can and will run hot. Ours was generally run at its limits, except for cultivating.
