Posted by pete 23 on September 10, 2009 at 10:44:47 from (173.87.8.73):
In Reply to: Farmall H-DisCharging posted by Dave42H on September 10, 2009 at 09:07:37:
System should never show heavy discharge at low idle (unless you have a load on such as lights) as the cut out should disconnect gen from battery. This is a problem with using 8 volt batteries, cut out needs to be set above the static 8 volt battery reading of approx 8.4 volts and charging voltage set on regulator portion to approx 9.2 volts. Most people do not have the knowledge of how to do this and although it can be done without special equipment other than a multi meter you have to know what you are shooting for. You need a fully charged battery to start with so voltage will rise to the point where it can be regulated.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
