Posted by Bob M on September 10, 2009 at 10:46:26 from (151.190.254.108):
In Reply to: Farmall H-DisCharging posted by Dave42H on September 10, 2009 at 09:07:37:
Sounds like a failing voltage regulator...
Test by temporarily grounding the regulator's FLD terminal with the engine running at governed RPM. If the ammeter now shows a strong charge (15 amps or so) the problem is the VR - specifically the contact points on the regulator relay.
If grounding the FLD gets a good charge you can try gently cleaning the points with an ignition file or emery paper - it may solve the problem. (Note - the regulator relay is the relay with its contacts held CLOSED by spring pressure). However if that doesn't work a replacement regulator is the next step.
Note also unless a 6 volt regulator is adjusted for 8 volts it will not properly charge an 8 volt battery! Better to address the need for the 8 volt battery in the first place (most often inadequate battery cables) and install a 6 volt battery.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
