Posted by M Diesel on September 10, 2009 at 13:24:24 from (12.24.61.12):
In Reply to: TD-6 Injection pump posted by Bob And on September 09, 2009 at 20:27:03:
As stated, the lift pump is that lump on the rear end of the main pump. The part where the fuel lines attach. There is a little seal in there that gives way over time. If your pump is old enough to NOT have an "A" or "IH" cast in big letters, you will have to make the packing gland for the lift pump shaft.
BTW, 35 to 40 psi is typical, and usable, but 58 to 65 is the spec. Low pressure limits upper end power a bit but not bad. Besides end plate wear, the control spring just gets tired after a while. Just about every pump I have has showed up in that condition.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
