Nearly all the H and M tractors sent to the UK from 1939 to 1949 were wide front tractors. I have a 1945 H and a 1949 M and they are both wide fronts. The few 3 wheelers that came herh were fitted with a single front wheel. All the wide front tractors had the axle set in the rear position and i think this was done to get more tractors on the ships. MJ
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
