1066 rear tire not running straight
Posted by Michael Sheik on September 11, 2009 at 04:35:53 from (199.153.192.254):
Going down the road I can watch the right rear and you can see it going from side to side about an inch and a half. Causes rocking in high 3rd or 4th. I know all the wheel bolts are tight and axle clamp is too. What I don't know is if the tire is that much out of round(side to side) or whether the wheel is bent or maybe wheel is not bolted on straight. I'm hoping it is the latter as maybe that is an easy fix. Can I jack up that side and block and run to check and can the wheel bolts be loosened and retightened to adjust.
