Posted by theponyroper on September 11, 2009 at 05:42:07 from (199.154.117.32):
Got a call from the implement shop yesterday. They put the flow meter on the hydro to see why it is slipping and the mechanic told me the readings were 3,000 pounds in reverse and 1,800 in forward. He's sure the hydro is worn because he said it should be putting out about 5,000 pounds. My question is why are the readings so different in forward and reverse? He is going to take the high pressure relief valves out and look at them and also will check for a cracked line but I'm wondering if replacing the valves will help and if that will bring the pressure in the forward valve up to the same as the reverse valve. The hydro has adequate power the way it is for loader and mowing work so if they can get the forward pressure up to 3,000 I plan to run it that way until the hydro gets much worse. Is there anything else that could be causing the two valves to have that much variation in pressure?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
