Re: H Liftall leak
Posted by Janicholson on September 11, 2009 at 06:58:29 from (199.17.6.222):
In Reply to: H Liftall leak posted by David Terry on September 10, 2009 at 18:35:11:
The cylinders can be hooked together at the rear with one hose going forward to the front elbow on the left, or the elbow on the right (either, because they connect together inside, and one 1/2" hose is plenty) Leave the rear left elbow alone, as it is a delay port and not for this application. If the hitch cylinders are setup with hoses from the top of each, these can also be T'd together in the rear, then a single line brought forward to connect to a T in the reservoir drain (bottom of tractor. This allows extra capacity for more hydraulic oil by using the top of the cylinder for volume. If the cylinders are setup with vents at the top, and it works, just leave it alone in that area. JimN
