Re: 5th gear in Farmall F-20
Posted by Pete in Holland, MI on September 11, 2009 at 10:34:44 from (198.36.95.12):
In Reply to: 5th gear in Farmall F-20 posted by Austin Miiller on September 11, 2009 at 10:08:54:
Your gears in the transmission and outboard reductions are all straight cut gears, thus will be inherentily noisy.
Yes, they do require lubrication.
The outboard reductions have a check and drain port (pipe plug) between the housing and wheel. The transmission also has a check port, but can't really remember where it is at this moment.
You'll want 90 or 140 weight oil for either.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
