Re: 1973 IH 766 chokes out when trying to throttle it up.
Posted by ChrisB2 on September 11, 2009 at 11:32:41 from (206.72.38.109):
In Reply to: Re: 1973 IH 766 chokes out when trying to throttle it up. posted by mkirsch on September 11, 2009 at 05:10:43:
Thank you for your reply. I forgot to mention that I had the carburator rebuilt as well. Do you know where I can find what the adjustments should be for this rig so I can compare against what it is currently set at.
