Re: Mackinac Bridge tractor tour
Posted by jdemaris on September 11, 2009 at 12:00:13 from (67.142.130.16):
In Reply to: Re: Mackinac Bridge tractor tour posted by Pete in Holland, MI on September 11, 2009 at 08:35:59:
I've got a place nearby and am going as a spectator. Too much work to register and run any tractors there.
I doubt the name-origin quite works as you've described. "Mackinac" was an attempt at spelling part of the Wendat and/or Ojibway Indian name for a "big turtle" which was big part of their culture. The Mac Island was the "big turtle", as were many other things. The original attempt at spelling the spoken word from the Indians was "Michilimackinac." Back then, often French or English speakers couldn't even find letters that replicated some of the actual sounds they were hearing from the Indians. My name (which is French) originally had the number 8 in it, instead of a letter. That because the number 8 in French, when spoken, best replicates the sound of the Indian sound.
"Mackinaw" was a name derived from cloth that some Métis Indians made for non-Indians.
As far as who named what and why, later, we will probably never been know for sure. You've got a bunch of non-Indians who tried to use non-Indian written language to use Indian words. Then later, you've got non-French and non-British-English speakers changing spellings even more.
Same problem even exits with the names we use for the Indian tribes. The name Ojibwa and Huron are names non-Indians made up and not what they called themselves.
By the way, I've met quite a few native Michigan people who think the big bridge is spelled "Mackinaw." So, it's not just the trolls below the bridge, or out-of-staters.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
