Re: Farmall M won't run at 180 psi compression
Posted by The tractor vet on September 11, 2009 at 14:21:44 from (76.212.229.66):
In Reply to: Farmall M won't run at 180 psi compression posted by LarryM on September 11, 2009 at 14:08:45:
Check total advance timing DO NOT GO OVER 28 DEGREES at wide open throttle open the load screw up five turns and see what ya have then , ya may need to trick out the carb and give her more air and fuel . I am not having any problems with one that is pushing over 195 on a stock ing . system and 93 gas and she will dyno well over 80
And my self i am not a big fan of them electroinic ing. systems . I can change a lot of points before it makes up the cost of one of them and if a set of points does go bad in the field i can always nurse it back to the barn and put a new set in and be back to work in fifteen min .
