460 Utility TA HELP
Posted by B Mack on September 11, 2009 at 15:35:01 from (70.106.165.114):
I realy need some advice and opinions I bought a 460 utility gas from a trusted friend ??? only saw a picture of it I asked about the TA he said the utilitys didnt have it. My tractor has no lever or linkage but you can see where a shaft would go through the middle and also a hole for pin on clutch shaft and the shift decal has D,TA. Tractor runs great the gears seem a bit slow like its in low except 5 th runs out like an M I can stand on one brake and it will keep pulling. In 4 th gear if I make a sharp turn it slows down. Im sure it would be costly to make it right I tell you I have been near sick over it havent said a word to my trusted friend ??? Sad thing is I really like this tractor Thanks in advance for any advice
