I have 220 psi per cylinder and that is only 10.750 to 1 compression.
In your intake manifold tap a small hole for a vacume gauge. Under full load "on dyno" it should read almost zero. If it is produceing vacume then your running lean and it needs more fuel.
Do you have a fuel pump on it or is it still gravity feed ?
You are on the verge of race fuel and it wouldn't hurt , don't use A/F gas it has antifreeze in it.
Set your timing on the dyno under full load , go for highest rpm under load. We use a digital timing light with a tach in it.
Email me direct if you have any more questions, i run a dyno service.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
