I have had the pump for over 25 years but it was never used much. Should be in good shape. Northern Hydraulics Catalog says it has 2.32 cubic inch per revolution. I think it will put out 15 gallons per minute at 1600 engine rpm. Pressure limit is 3000 psi.
I am actually running the Lewis-Shepard pallet stacker mast with its original electric-hydraulic pump and reservoir. Capacity is 2000 lbs. You can see the high amp plugs in the last picture. The whole rig is quick disconnect as it is fast hitch coupled.
The clutch pump will run an IH balanced head sickle bar mower. I will cut the top and sides of my hedge with it. I had the mower on a Clark forklift but I could not see what I was doing as the hedge is eight feet high.
Yep, the driveshaft will run a Dana 60 front axle from the same Ford F-350. Don't expect any pictures in the near future. I will post some more pictures of the completed hedge clipper soon.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
