Re: Did I hurt it?
Posted by SDE on September 11, 2009 at 19:23:50 from (174.124.25.116):
In Reply to: Did I hurt it? posted by Bill in IL on September 11, 2009 at 19:17:25:
The fan belt turns the water pump. With out it the coolant will not circulate. If it did not sieze up it should be ok, but it will reach max. temp after it is shut off. If it cools slowly, it should not crack the head.
Any Damage? You won't know until after the next time you work it hard.
SDE
