Re: Farmall M won't run at 180 psi compression
Posted by ChadS on September 12, 2009 at 05:36:52 from (4.224.78.20):
In Reply to: Farmall M won't run at 180 psi compression posted by LarryM on September 11, 2009 at 14:08:45:
Needs more octane. Go get 5 gallons of E85, and 5 gallons of 93, pour the two cans of fuel in the tank and retune. If the head hasnt been tightend down correctly, the head will float from the nuts being loose when it warms up, and the valve lash setting will tighten up and loosen up, holding a valve open, just enough to lose cyl pressure. This engine will need a #29 venturi, OR, a W9 carburator would do it a world of good. Hope this helps. ChadS
