Posted by JMOR on September 12, 2009 at 10:13:04 from (72.181.156.161):
In Reply to: pertronix coil posted by d282 on September 12, 2009 at 07:40:23:
LN said: (quoted from post at 10:40:23 09/12/09) should you have an inline resistor before the coil of a farmall M when using pertronix ignitor #1442 and pertronix coil #40611 40k volts have read the literature and listened to a lot of advice but would like to know for sure before I burn it up
If you are still 6v, then with that 3 ohm coil, you are only running a meager 2 amps.........not going to burn it up, but not a lot of energy either. I believe that if you contact Pertronix, you will find that it is intended to run at about 4 amps.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
