Re: Farmall 504 Clutch Issues: All Suggestions Welcome
Posted by Wardner on September 12, 2009 at 12:22:56 from (4.154.247.231):
In Reply to: Re: Farmall 504 Clutch Issues: All Suggestions Welcome posted by charles todd on September 12, 2009 at 10:21:16:
I am not much of a maintenance or troublshooting
guy but I have two thoughts.
It sounds like pilot bearing trouble. Although I
have and use a 504, I have never had any clutch or
TA problems so I don't even what kind of access
you have for testing the pilot bearing even if
that can be done.
The other thought is the integral IPTO gear and
hollow shaft is putting a drag on the clutch
shaft, that runs inside of it, when the clutch is
disengaged. Not sure if there is access to clean
that annular space with air or high pressure
water.
Apart from those two suggestions, I think most
people would say you have pressure plate or clutch
disc problems. They may be right. Have you tried
Red Power forum?
