Re: Touch Control
Posted by Hugh MacKay on September 12, 2009 at 17:22:31 from (209.226.247.105):
In Reply to: Touch Control posted by Vern on September 12, 2009 at 15:43:00:
Vern: No, there is no vent. That is why it's important to fill the system with both rockshaft arms in rear position. Very important also to leave cap off at low idle, then work both rockshafts full stroke several times to expell all air. You may find it requires more oil after doing that, and again do it with rockshafts in rear position.
Failure to do it this way, may result in popping a frost plug type plug behind rockshafts. Not hard to replace, just hard to get at.
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the ... [Read Article]
