Re: MD transmissions woes! Please help!
Posted by SDE on September 13, 2009 at 06:21:59 from (174.124.28.95):
In Reply to: MD transmissions woes! Please help! posted by BruceS. on September 13, 2009 at 04:55:26:
You should pull the shift lever out of the deck by removing the three bolts that surround it. With a big screw driver, realign the shift rails to the neutral position. Now look at the bottom of the shift lever. The worn corners need to be built up, or it will happen again and again.
SDE
