Re: 40 B boiling
Posted by Red Dave on September 13, 2009 at 13:50:21 from (98.235.15.235):
In Reply to: 40 B boiling posted by Curtis Scott on September 13, 2009 at 13:12:15:
It has a non-pressurized thermo-syphon cooling system. No water pump, no thermostat, at least not from the factory.
Not unusual for them to make gurgling sounds after it is shut down.
Make sure that the radiator is full so that the thermo-syphon can work. If it seems to be overheating, you may need to flush dirt and rust out of the radiator and block.
